1 - 3 of 3 Posts
Hi forum.
I need some help to choose my next LCD monitor.
I was impressed by the blacks (and dark colors in general) displayed by LED TVs, so I was thinking to upgrade my good old BenQ FP24WZ.
These are the features I'm searching for:
- Dimesions: 24"-28"
- Res: 1920x1200 (possibly, but 1080 is ok)
- 3D ready (so at least 120Hz right?)
- DVI-D and HDMI (I think every monitor out there has it)
Possible uses:
- Bluray movies
- Videogaming (Xbox 360, PS3, PC)
While searching I found the BenQ XL2410T, but I coulden't find any reviews.
I think this model has edge leds.
Now one more question: according to you, will I experience a big difference from this upgrade (classic LCD -> LED LCD)?
Thanks for helping!
Depending on what you get you might not see a difference at all. CCLF backlit models can be quite good and, depending on who you talk to, can even produce a better picture than an LED backlit. You really need to do a side by side comparison if you can and then decide which looks better to you - in the end that's all that really matters!
1 - 3 of 3 Posts
