1 - 7 of 7 Posts
Discussion Starter #1
Hi
I want to hang a flat screen sideways and make a movie poster frame where I can send movie posters to display.
What's involved?
1. LED TV
2. Mini PC for program? I found this: https://www.amazon.com/Pro-X5-Z8350-Processor-Graphics-Bluetooth/dp/B07VWQWZBT/ref=sr_1_13?dchild=1&keywords=mini+pc+windows&qid=1594911198&s=electronics&sr=1-13
3. Software: EG https://www.movieposterapp.com/
Am I missing something or better way??
Nice idea is integrate with K-scape ?
Discussion Starter #4
I can certainly try it... Should like fine.
Are there any mounts that are designed to be placed at a perpendicular for a 40" LED?
BTW - I'm new to this. What type of file or files do I import to the USB so it'll play? One movie poster at a time or can do many like a slide show?
Thanks so much!
Hi
What's involved?
1. LED TV
I'm currently doing this myself as well. I'm using the following;
1. 43" Vizio 4K LED TV
https://www.walmart.com/ip/VIZIO-43-Class-4K-UHD-LED-SmartCast-Smart-TV-HDR-V-Series-V435-H/838222479
2. Raspberry Pi4
https://www.amazon.com/CanaKit-Raspberry-4GB-Starter-MAX/dp/B07XPHWPRB
3. MovieNow App
https://www.movienowapp.de/index.php?sid=19da91b072df98d66858b44e2a8e901f
I'm all in for about $450 plus building a frame around the TV. Can be done a little cheaper now that I have put all this together. The MovieNow App works great and comes with 1000's of movie posters.
Premium Member
I am using the Samsung frame for the display. Using a low end intel Nuc.
1 - 7 of 7 Posts
