Status
Not open for further replies.
1 - 2 of 2 Posts
I've got a (new) Leeza that I'm hoping to use with my ceiling mounted G15U and a 16:9 screen. My problem is that I can't find any settings that will work properly with this configuration.
If I set the output to 1365x768, I have a second "frame" of the movie in split-screen below the bottom of my screen (i.e. using the top 256 pixels of the panel which "live" there). If I set the output to 1365x1024, however, I can't get correct aspect ratios.
Am I missing something? Screwed?
Marc
p.s. This works properly on a Rock+ using the 1365x768 (BOTTOM) mode.
Banned
Ok, Marc I have the same setup so here goes.
Assuming you do not have a panny or isco lens, this is what you do.
The G15 is set to sxga3
1 The Leeza resolution is set to 1365x1024
2 . You tell the Leeza that your screen size is 1.33. It doesnt matter what screen format you are using, 16x9 or 4x3
If you are using an anamorphic lens, then you change the screen size to 1.78
Hope this helps. By the way, didnt you have a Rock. If so what happened to it
1 - 2 of 2 Posts
Status
