Hi,
I am setting up my video distribution system, and for that I acquired the Leviton Video Service Module .
The main reason I got this particular item over other alternatives was because it supposedly allows the DC signal of the remotes to go through, which I need because I am using the same coaxial cable network to distribute the IR signal.
However, I am having two problems with this item, and I figured that someone here might be able to help me:
1. The panel has 3 inputs: one CATV and two from modulators. If only the modulators are connected, the TV image looks fine. But as soon as I connect the cable TV, it looks like it is interfering with the other two inputs.
Note: I don't have a low pass filter on my cable. I figured I don't need one since my cable service doesn't use the channels 90-94 that I'm using for my modulators. Do I need the low pass filter anyway? Could this be causing this interference?
2. The IR signal is not passing through. I am using Xantech Injectors, Couples, Receivers and Emitters. In a direct coaxial cable (not going through the panel), it works like a charm. But as soon as I put the panel in the middle, the system stops working. Does anyone has this panel working with IR distribution in place?
Thanks all for your help.
