HI, First post here so bare with me...
I just purchased a Leviton 48211-WVK Chopin Digital Volume Control Kit . It comes with 2 in-wall volume controls, and a volume control HUB.
The way I understand it to work is as follows.
Speaker wire from back of Reciever into the Leviton HUB,. The HUB has one set of speaker outs which I understand can support up to three sets of speakers if hooked up properly. The HUB also has a single CAT5E output which is meant to run to the volume control in the wall.
Simple enough, but what I want to do is have 2 sets of speakers running from the single HUB. Leviton Instruction manaul says this can be done, and it also says up to 3 volume controls can be hooked to the single Leviton HUB.
What I want to know is how to hook up 2 sets of speakers in different rooms with corresponding volume controls in each room all back to the same HUB.
On the back of the volume controls for the wall are two CAT5 inputs, or 1 input 1 out put. Not to sure. DO I hook the volume controls together from one to the other with a CAT5e (so out from the hub into the first CAT5 volume control, then out from that volume control into the other volume control, or do I need some other hardware...??
DOES anyone at this forum know how to work with this product. LEVITON VOLUME CONTROL UNIT.
ANy help would be much appreciated.
