Status
Not open for further replies.
1 - 5 of 5 Posts
· Registered
OK I give, what's the answer? I had an DIO 24/96 that at least passed DTS but when I upgraded to the Audiofile I've had nothing but trouble.
I first tried the driver on the CD and it locked my Win2K up so tight that I had to reload the OS from scratch, (repair wouldn't even do it). Then, like an idiot, I thought that a clean install was all that was needed. BAM! Locked W2k up again.
OK, third time's the charm so another clean install and this time I downloaded the latest driver from Midiman and at least I get sound. But all I get is 48KHz, no DD or DTS.
Is there some magic I'm missing? Some secret beta driver? I'd hate to go back to my DIO after all this effort. :(
TIA,
Phil
· Registered
Phil,
Here is the secret location of the secret beta drivers that has the new AC-3 switching logic. It is listed under Delta_ver_27_final_2 for the Delta 410/1010/1010LT cards.
http://www.digitalconnection.com/Support/support8.asp
Use the included Delta-Uninstaller to remove the old drivers before installing this version. Also make sure that the S/PDIF is selected for output in Sounds and Audio Devices.
· Registered
Discussion Starter · #3 ·
Cliff,
Thanks for the quick response. I'll give it a try later today. My I assume that it does DTS as well?
In other late breaking news Lexicon has had so many complaints about this that they have offered a utility to unload their patch until the fix for the Pro bit is available.
Thanks again,
Phil
1 - 5 of 5 Posts
Status
