No difference at all in PQ between the LG 3200A and the Sony HD300. I also have a Sony HD200, and I agree that the 3200A/HD300 "may" be slightly less sharp on the component output than the HD200. But the difference, if any (on a Sony 32" plasma monitor) is very small. On the other hand, the S-video output on the 3200A/HD300 looks slightly sharper and with more saturated colors than on the HD200. Again, the difference, if any, is small.
I have experienced no audio dropouts with the LG or either of the two HD300s that I tested.
I have not opened the units, but the LG and corresponding Sony clearly must have different front-panel circuit boards, because their geometry is different (the buttons and the card slot are in different locations). However, the two versions of the front-panel board "should" be electrically and electronically equivalent, just with their components re-arranged a bit. Typically such boards are connected to the main board by a ribbon cable, so if the only difference is in the layouts of the front-panel boards, it's hard to imagine that could be the root cause any of the reported problems.
The two Sony HD300s that I tested, bought from different places, both consistently exhibited the "composite/S-video black & white problem" on channel 201. (And another source has confirmed to me that DirecTV *DOES* test the HDCP flag quite often on that channel.) But the LG 3200A has NEVER done this, and I have had it for 5 days now. The Sony and the LG have the same main board rev level and the same firmware rev level — so what can the difference be?
My "best guess" is that the HDCP flag causes the firmware, although identical, to take a "bad branch" when running on the Sony version. It's clear that the firmware, although the "binaries" are identical, is sensitive to which make it is running on. Not only does the firmware respond to different IR codes (and different RF codes, too, I have tested it) but there are minor differences in the menus. The Sony displays the select button as something similar to a "+" sign, whereas the LG displays it as a circle with a dot in the middle; there are minor differences in the menu text (the LG uses the term "Surf", the Sony does not); and the procedure for changing the remote codes differs between the Sony and LG models.
(Another mystery is that the RF remote antennas are NOT interchangeable — the Sony will not respond when the LG's RF antenna is connected, and vice versa. Somebody else reported this, but I forgot about it until it "bit me". The LG's RF antenna is about 3/4" shorter than the Sony's, which indicates they are tuned for different RF frequencies, but it's hard to imagine that matters much at VERY short range. Most likely, the RF antenna units themselves contain very narrow band-pass filters in their bases. Also, the Sony supports 16 different RF code sets but the LG supports only 8 such code sets. On the other hand, the Sony supports only 2 sets of IR codes, while the LG supports 8 such sets.)
Originally posted by Ken Ross Bill, do you see any differences at all in the PQ between the LG and the Sony. |
