1 - 4 of 4 Posts
Does anyone have great calibration settings for LG 47LK520 or know where to find them, I have looked everywhere, new to site so I guess this is where i would post this?
Greetings
Welcome to the forum.
http://www.tlvexp.ca/2012/12/the-fruits-of-copying-settings-the-pioneer-lottery/
Copying settings gets you a whopping 4% chance of doing better than the stock movie mode in a TV. And this was on the most expensive TVs too. This also means that you have a greater than 96% chance of making things worse than the stock mode ... or coming up with something little different than stock.
But if you are not in the mood to actually verify if copied settings actually gave you a better result (needs test equipment) ... then you just keep swapping numbers until you end up with something you "like" which has nothing to do with what things are supposed to look like or "calibration" for that matter. Then what are you doing in a calibration forum?
If you just get a test disc and follow the instructions ... you will end up much better than any copied numbers can get you. Test discs start from free and go to about $40. Then watch the tutorials on my site that teach you how to set the user controls.
http://www.tlvexp.ca/2013/03/poor-tv-picture-quality-not-happy/
This article lays out your only reasonable alternatives.
1. Buy a test disc and learn how to use it ($0 to $40)
2. Buy a test disc and software and hardware and learn how to use all that. You will get a better result eventually ... may take a year of learning to get there. Scrounging for tidbits of information here and there. ($150-$500 for gear) Cost of your time = $0
3. Hire a good professional calibrator to get your TV set up right ... the first time. And you get the confidence as well. ($300-$500)
4. Buy a test disc and software and hardware and pay for professional level training on how to do this. Cost of training is $100 to $2000+ and paying more does not always mean you get a better product.
regards
Greetings
Suggest you go to the TLVEXP site and watch the tutorial videos ... as they should help you with this ... patterns are similar ,,, (requires some lateral thinking)
regards
1 - 4 of 4 Posts
