1 - 20 of 77 Posts
My 3 year old LG 60" plasma tv (60PV250-UB.AUSZLUR) started having some issues in the middle to top part of the screen where the colors are shifting to different colors. Especially in white and light areas. If the screen goes white, there are basically clouds of area that are green or purple. They will stay there, then go away for a second, and come right back. It is especially bad when peoples faces are on the screen. Oddly enough, usually after about 4+ hours of continuous use, it stops. But if you turn off the tv, and turn it right back on, the problem is back. This happens on all inputs, with a computer hooked up, ps3, etc. It also happens when the TV's main menu is up. Thoughts?
This is a common issue on these sets. It is caused by some cold solder joints under the ER coils on the Z-sustain or Y-sustain. If you have access to a soldering iron and some leaded solder (lead-free can work but is more difficult to use) then you can repair it.
From the picture , it looks like what my now 2yr old PA6500 problem was/had , which I called "dancing purple/pinks" ; and seemed to pop up sporadically but mostly in light colored areas . This problem showed up just before my 1yr warranty expired so it was covered . LG first replaced the main processor board ... problem still persisted . LG then replaced the screen and two more of the boards to finally fix the problem .
Discussion Starter · #4 ·
If I pop open the back, are you saying I will notice loose solder joints on the Z and Y, or are you saying I would need to resolder all the joints?
Once you remove the Y-sustain and Z-sustain the cracked joints will usually be obvious. If you post a picture of the sustain boards I can highlight the coils of interest which would narrow down your search.
My LG 60PV250 started doing the same thing this year, it's gotten really annoying. I haven't taken the back off of my set, but I've attached some photos of the sustain boards from ShopJimmy.com. Thanks for any help tom669.
OK in your case the coils are between the silver and black heatsink on the Y-sustain and Z-sustain. The three coils in a row. The solder joints under them can crack.
Thanks for your help tom669, I'll have to practice my soldering on some junk circuit boards before I work up the nerve to try to repair my LG TV, but at least now I know what to look for.
Discussion Starter · #9 ·
Can anyone tell me how long it would take unplugged for the capacitors to lose their charge? Or would I need to use a plasma discharge tool?
This is exactly what my 60" LG plasma is now doing, it's also really hot to the touch! On a whim, emailed LG early this morn & cust svc wrote back req'ing all my info serial # date of purchase to do a out of warranty repair! Hope they come through as I'm not comfortable taking the back off much less using a solder iron lol.
LG declined to do an out of warranty fix, too far oow. Now the search begins for a new tv! Anybody want a slightly used tv with some ghosting lollol??? :D
Hey I have the 60PV450 and just started having the same problem. I'm pretty mechanically inclined but have never soldered before. Would you recommend I call in a tv repair service to resolder or just buy new xsus an ysus panels and install them myself? Would I have to replace both of those or is just one the culprit for the purple haze?
Just Curious
Any idea if the y or x sus seem to be causing these problems? Or both? Also will tweaking any of the pots help eliminate it at all?
Personally, I'd like to see in the near future someone filing a Class Action Lawsuit against LG for their obvious defects on these models. badcaps dot net has numerous threads about this plasma model for those trying to do their own repairs. Works for most from what I read, but I'm still not inclined to do surgery on a tv that isn't 4 years old & calling a tv repairman prob isn't worth it as I'm in a rural area & they'd have to travel etc. Just don't think putting another ~$400 into this tv would be worth it.:mad: Otoh, gives me something to look forward to on Black Friday Ha! :rolleyes:
The soldered coils on the back of the X sus board were cracked just like Tom said. I took it to the local tv repair shop and paid the $15 to have them resoldered and works like new. No purple/green haze on light colors anymore and super good picture. Thanks Tom.
Thank you all for this thread on how to solve the Plasma tv from flickering and wierd colors splotches.
i was about to give in to having to buy an LCD TV not that they are bad but i do love my 60" LG Plasma TV it is about 2 years old now and for the past week it started this wierd colored splotches and slowly got worse as the week went by.
I was not and will not send in any of my electronics to get them fixed for me i always lose money and time and in most cases with me the fix is short lived.
So my options was ether to fix it my self or buy new.
Thanks to tom669 and every one on this thread for the info i did the fix my self and my (( Vision of god )) is back to working like new again and so i can go back to worshiping my Tv.
The photo of the TV on the bed shows it open and the Board to the top right is the one that had the COILS with broken solder.
Also a few before and after photos of my handy work before you can see the broken solder on two of the three COILS. and after you can see my work of the new solder at least it wont brake again in the same place.
Thank you all fore sharing this info.
Well I too can be added to this esteemed list of owners!. :( I can solder and just wanted to ask about the photos above. The BEFORE. Is the broken welds those spikes sticking up in the pics? The AFTER: Is it okay that the spikes are now soldered to those nearby diagonal solder pads?
Hope I'm able to fix mine!> Just started yesterday and its horrible!.
Or!. Should I tell the wife HHGreg has a 65in Toshiba 240hz SmartTV on sale? ;)
Thank you everyone for posting this information. I just successfully repaired the solder joints on both boards. The board on the right side when standing behind the TV had the most obvious broken solders and the board on the far left looked ok but seemed like it wouldn't be long before they would break so I re-soldered those as well.
My glorious Picture is back!.
Thanks everyone!
:eek: THIS EXACT SAME ISSUE STARTED HAPPENING ON MY 60PZ750-UG Plasma THIS WEEK! We've had it since 2011 NEVER Had a problem and now ALL OF A SUDDEN! THIS?
Thankfully with the tips left by everyone on this Dreaded and feared LG 60 Color Splotches, I too should be able to fix...
I only have one question though... Based of a previously shared sustain board "AFTER REPAIR" picture from, is the following attached picture the correct Solder points MARKED WITH A RED ARROWS we're looking for and correctly re-solder?
Please ADVISE? :(
I just did this fix on my 60" LG Plasma today. Funny that I had my TV since 2011 also and it just started having this issue. That soldering job in the picture is quite sloppy. There is no need to have all that solder on one joint with it touching the other pads. Try to keep the solder localized to the one joint and it will work just fine.
Please ADVISE? :(
1 - 20 of 77 Posts
