SD DVD Region was 0 as set by the RMTM CD. It looks like, if you run the RMTM CD, you can't subsequently change the SD region code using the Byte 4. SD region coding can only be changed using the RMTM CD again. This doesn't seem to be a problem except in testing what the EEPROM string means. Anyway, under 96 PAL playback is fine and there is no Network Update option.
Region A playback is not possible with 96 (tested with The Lives of Others, Sony, US, Region A Locked). However, you don't need to reboot the BH200 to change the BD region code. I was able to swap between Region A and B and play Region A- and B-locked movies using PAUSE-1-4-7-2 and changing Byte 4 between 8D and 96.
I guess we need some more non-US BH200 users to post their Byte 4s and see if we can work out the patterns. Ones I have tried are:
00 = 0000 0000 = R1/RA/NTSC/Network Update
80 = 1000 0000 = R1/RA/NTSC+PAL/Network Update
82 = 1000 0010 = R2/RA/NTSC+PAL/No Network Update
8D = 1000 1101 = R4/RA/NTSC+PAL/Network Update
96 = 1001 0110 = R2?/RB/NTSC+PAL/No Network Update
I don't know if the binary values are in any way significant, but it might be the case that Bit 1 enables PAL and maybe Bit 4 is the BD region code. The SD region code could be somewhere in Bits 5-8 but the pattern isn't obvious. Anyway it might not be binary at all, there could be an internal table that translates between the EEPROM numbers and a matrix of values.
I seem to remember that the BD region coding is designed such that there can be no such thing as a multi-region BD player, it has to decide each time whether it's going to be A, B or C. All of the (hardware!) BD multi-region solutions have involved switching between A or B. So we may be out of luck finding a single EEPROM value that will allow A/B/C playback, but the little LG has already surprised us.
As far as I know this is by far the simplest way to play an off-region BD in any BD player. The others involve hardware or flashing the whole firmware. Ours doesn't even need a reboot, though you need to be handy with the remote.
I'd love to sit here and test all the possible Byte 4 values, but given the risk of bricking I might leave that to someone who lives closer to where they bought the unit.
Originally Posted by bradavon /forum/post/13808591
WOW! I'm impressed.
* What was the SD DVD Region?
* Could you still play PAL Region 2 SD DVDs?
* I presume you could then not play Region A BDs?
* Is the Network Update option still available?
Actually it probably doesn't matter too much what the SD DVD Region number said (as we have the RMTM CD) but it's still worth knowing.
