Saw this old thread for LCDs and seemed interesting. Anyone with DLP try this?
http://www.avsforum.com/avs-vb/showt...=bias+lighting
Originally Posted by audiofan1 /forum/post/20881271
I bought the diodes from Ikea a year ago for my Pioneer 64 rear projection set which has since died and I use them with my recently purchased Mitsu 73738, It makes the set appear as though its floating in mid air. This is great for viewing my tv shows in HD, but they are off when watching movies![]()
Originally Posted by GeorgeAB /forum/post/20888798
The IKEA Dioder (white LED version) has been measured to be between 5000K and 5500K.
Originally Posted by jaball77 /forum/post/20893988
Why does the color temperature matter? Chances are you're not going to be lighting a 100% pure white wall behind the display anyway.
Originally Posted by rich3fan /forum/post/20894296
Not here to troll... but I thought that a big feature of DLP RP technology was that ambient room lighting would have no effect on Black (or any) levels that the TV displayed. "Am I wrong?" audiofan1 says it makes his DLP appear as though it's floating, but that doesn't really answer the question of whether or not bias lighting helps black levels.![]()
Originally Posted by JukeBox360 /forum/post/20894192
I've been trying to find a 6500 led rope light. I don't like using a random bulb.
Originally Posted by GeorgeAB /forum/post/20895665
The LED rope lights I have tested, that claimed to be 6500K, were way too blue. They measured between 8000K and 16000K. There appears to a pattern with Chinese LED manufacturers where they call anything that looks to be bluish white as "6500K." All so-called "native white" LEDs are actually bluish white. You can see them commonly featured in solar path lights in most neighborhoods. LEDs with lower color temperatures must add either yellow phosphor in the diode capsules or place a yellow filter over them to make them less blue. The yellow filtering is showing up in hardware stores on LED screw in light bulb replacement products.
Originally Posted by JukeBox360 /forum/post/20898206
Hmm. Even the 65K bulb I used seemed a bit blue. I know I'd really like the rope more then a bulb though. Any local hardware store that sells rope that's close enough for what I need it for?
