The RadioRA2 is a very solid, pro level system. It doesn't have a lot of bells and whistles but it almost always just works basically. And the automation system interface is available and straightforward, which is nice from my point of view as an automation system vendor.
Zigbee is nice, but in terms of open Zigbee systems there aren't a lot of them to choose from yet. Most vendors are choosing to use proprietary Zigbee stacks which means their Zigbee based widgets will only work with their controllers. They probably see no reason to do the work and let others benefit from it I guess. Of course RadioRA2 widgets only work with RadioRA2 as well, AFAIK, but it's not pretending to be an open standard, which Zigbee is often thought of as being, which confuses the issue. Zigbee can be open but doesn't have to be.
What Zigbee-based system is being recommended? If using Zigbee means you are buying into a whole specific automation system, then that's sort of different than if it's just Zigbee lighting that can be integrated into whatever automation system you might want to use at some point. RA2 is also somewhat of a world unto itself in so far as the actual hardware, but it's designed to be easily integrated into 3rd party automation systems.
Even if you do settle on an open Zigbee-based lighting system, and it provided an integration interface to automation systems, it's not necessarily the case that any particular automation system you might choose would be able at this point to integrate to Zigbee, though it's probably becoming more common. For RA2 it's just an IP connection.
