I know this has been asked a gazilion times. And I know I really should have my Barco 1208 on its own circuit...
I'm in the process of finishing off an over the garage unfinshed space into a home theater. The problem is, they only ran a single 15A circuit to the room. It does appear to be on its own circuit though.
There is literally no way to get another wire to the fuse box. The fuse box is in a room with sheetrock all around and a room above.
The question is... do you thing I can squeek by on the one circuit. I'm running 12 40-60 watt recessed lights and a rope light. The equipment will be fairly light with one HTPC and an Onkyo 6.1 system (no array of heavy amps). Also, the Barco 1208. There will be some misc stuff also such as a wireless router.
I have run all 12g wire, but the wire coming from the fuse box is 14g (so Its probably all for not). I'm assuming it isn't a good idea to swap out the 15AMP switch for a 20AMP one.
