Status
Not open for further replies.
1 - 1 of 1 Posts
hi team
my set up:
win xp pro 2600 (without any updates)
ati radeon 32 mb ddr - driver, 6.13.10.6071
maudio delta dio - driver, delta wdm 5.10.0.27
windvd 4.0 plus
powerdvd 4.0 xp
regionkiller 2.5.0.1
powerstrip 3.15
1280 x 720 @ 71.904
barco cine 7 limo
i played around with the settings and this is what i discovered so far.
start -> settings -> control panel -> sound audio devices -> audio tab -> sound playback default device "m audio delta dio spdif"
windvd audio set up - spdif
windvd video set up - use hardware decode accel. off
a. windvd launch with mute 'on'
b. no dolby digital, no dts - only 2 s[peakers
with windvd video set up - use hardware decode accel. on
spdif is available, dts and dolby digital track plays normally but with slight lip sync problem. picture appears to be slightly ahead of audio.
but when i changed this setting during playback...
start -> settings -> control panel -> sound audio devices -> audio tab -> sound playback default device "m audio delta dio multi channel"
lip sync is immediately solved and doby digital and dts track plays beautifully too.
the setting has to be changed during playback or windvd will popup error message about not supporting dts track.
hope this helps... good luck
1 - 1 of 1 Posts
Status
