61 - 80 of 3164 Posts
There's these new listings on Amazon from some company called OSD whose claim to fame is making outdoor speakers.
OSD Audio PS12 High Powered 175W Premium 12-Inch Home Theatre Subwoofer
They have the "premium" model in 12 and 10" and a lesser (down firing) version for less.
The specs on the 12" premium model are quite fascinating.
It is rated from 5 (yep 5hz) t0 180hz -3db. All for less than $250. :)
http://www.amazon.com/OSD-Audio-PS12...162444&sr=1-27
You don't believe that do you
Newegg Energy S10.3 on sale till 24th.
Writer & Reviewer
Discussion Starter · #64 ·
It does indeed say 5Hz. What a phenomenal feat of engineering!
My guess is that's supposed to be 50Hz though, and I think I found the missing 0; instead of "to" 180Hz your wrote "t0", so it's all your fault.
OSD does make a few different models, all of which will be added. Thanks...
Writer & Reviewer
Discussion Starter · #65 ·
Added
Outdoor Speaker Depot (OSD) SS8, P8, S-10, S-12, PS10, PS12
Writer & Reviewer
Discussion Starter · #66 ·
Added
Pinnacle PS Sub 8-300, SubSonix 10-200, AC Sub 125, PS Sub 225
This obscure sub would be hard to recommend compared to known entities like BIC for about the same price. And, one could get 3 of the Monoprice 12 inch subs for the price of 1 OSD sub. The 15 X 16.5 X 15.5 dimensions are not inspiring. Maximum output at 45 Hz or higher with very very limited response below 35 hz is likely. The 2 so-called reviews are meaningless.
At least with the Monoprice sub you get what you are paying for.
Writer & Reviewer
Discussion Starter · #68 ·
Removed
Allison Acoustics AL10 (no longer being sold)
Writer & Reviewer
Discussion Starter · #69 ·
Added
Klipsch SW-350, Sub-10
Actually, looking at the OSD website: http://www.outdoorspeakerdepot.com/1...ofer-ps12.html
.... it is listed as going down to 25hz. For a 12-inch ported subwoofer of that size, the specifications seem reasonable. The amp on the back looks beefy for the price.
That looks like the AudioSource PSW112. The amp seems to be the exact same one too. The only difference is the controls in the back instead of on the front.
Writer & Reviewer
Discussion Starter · #72 ·
There is a similarity, isn't there? I'm thinking about ordering one of those OSD subs for my next review, as soon as I'm done with the XTZ (which should be this week). Perhaps I'll find out for myself what they're really like.
Writer & Reviewer
Discussion Starter · #73 ·
Added
Crystal Acoustics TX-8Sub
Earthquake Sub-80X
Legrand HT5104
Linear PSW108, PSW112
Niles Audio SW10
Of most of the subs in this place, which of them would be best for HT and music and gaming. I have done some research and the most prominent that sticks out is the Bic F-12...any others that would be decent for all around?
Woot, I have 2 F12 on their way. I've learn on this forum that the F12 isn't suited for music but it's ok as I use my system 95% for movies and gaming.
For you, the Polk PSW505 would be my first choice followed by the Lava LSP-12. Never heard the Lava but the 505, depending on the size of your room and with proper placement and tuning can make your eyeballs vibrate. The Lava gets respect here on AVS.
My two cents
Originally Posted by Interestedparty /forum/post/21074852
Yep...I am in the market, and think i am going to get an ultra 12, talked to emotiva yesterday, and they are going to lay the ultra 12 down...
wouldnt it be hard to repair the Ultra if it were to break down in the future since its discontinued?
and what do you guys mean its good for high volumes? what if you wanted to play it at low volumes?
Writer & Reviewer
Discussion Starter · #77 ·
Emotiva is a good company, so I don't think you'd have much to worry about. I believe the warranty is 5 years on parts and labor, so you should be set for a while.
Just to reiterate... the purpose of this thread isn't really to discuss any particular subwoofer, it's purely informational in nature. If you have specific questions about something it would be better to start a new thread, that way all the answers you get will be focused on your specific situation.
What about the BIC Acoustech PL-200? From the different threads I've found, it seems to be easily purchased for around $280.
I was going to get the F-12 for my first sub, but was able to purchase the PL-200 for $249 today.
I would say that the F-12 is easily the "best" for under $200.
Thanks for this thread! So much good info.
Just a quick heads up, right now on Amazon the Polk PSW505 is $179!
I think I am going to pull the trigger. Hard not to at that price.
