1041 - 1060 of 1083 Posts
I'll bet that most speaker systems have their sensitivity tested from 500Hz to 2k Hz, but I would prefer 20Hz to 20K Hz for full range speakers, 80 Hz to 20K Hz for speakers intended to be used with a subwoofer, and some standard range for subwoofers.
So I did the sensible thing to do and did what I should have done first: a Google search. These three articles at Lifewire, Audioholics and Audioreputation seem to agree that manufacturer sensitivity figures are an average in the 300 Hz to 3kHz band.
This means that subwoofer range is completely avoided in sensitivity figures, as they ignore the sub-300 Hz range. That also means that in practice, with a standard 80 Hz crossover, the system might use up more power to reach reference SPL than stated in sensitivity figure, because of the added load for reproducing 80-300 Hz content.
So contrary to what I thought, the real-life situation might not be *better* than what is shown in the spreadsheet, but in fact perhaps slightly worse (i.e. a speaker barely reaching reference levels according to the spreadsheet based on manufacturer sensitivity rating might not in fact reach it when playing lots of mid-bass for example).
Do you think I'm getting this right?
Link to Google Spreadsheet !
Link to [static, sorted by performance] published from Google doc .
Partial list below. Go to the PDF (below) or the Google spreadsheet for all info.
Klipsch\tKPT-Jubilee
Klipsch\tKPT-Jubilee 535
JTR\tTriple 12HT
ElectroVoice\tVariplex II HPK
JBL Pro\t4722N
Danley S. L.\tSH-50
Danley S. L.\tSM-60F
JBL Pro\t3722N
JBL Pro\t3732
Klipsch\tLa Scala II
Klipsch\tKlipschorn
Yamaha\tDSR112
Klipsch\tKLF-30
JTR\tTriple 8HT
QSC\tKW153
JBL Pro\t4670D
JBL Pro\t4675
QSC\tKW152
Klipsch\tCF-3
Danley S. L.\tSH-60M
ElectroVoice\tSx300Pi
Klipsch\tCornwall III
Klipsch\tKLF-20
JBL Pro\tMRX512M
Procella\tP860
QSC\tK12
QSC\tKW122
Genelec\t1036A
RWO Fostex\tLS/3
AudioKinesis \tThunderchild
JBL Pro\t3677
RWO Fostex\tLS/4
JBL Pro\t3678
Klipsch\tHeresy III
Seaton\tCatalyst
QSC\tK10
Tannoy\tDefinition Install DC12i
Carvin\tPM10
JTR\tSingle 8HT
Danley S. L.\tSH-100
Klipsch\tKL-650-THX
Chase\tSHO-10
eD\teD[c]12
Klipsch\tKL-525-THX
RWO Fostex\tLS/2
Peavey\tPR10
Genelec\t1038B
ElectroVoice\tSx100+
Pro Audio Tech.\tSCR12sm
QSC\tK8
ElectroVoice\tELX112
Mackie\tC200
Zu Audio\tOmen Center
Yorkville\tYX10
Chase\tPRO-10
Klipsch\tRC-62 II
eD\teD[c]6.Center
Triad\tInRoom LCR Platinum
Klipsch\tRB-81
JBL Pro\tLSR6332
Ayon Audio\tBlackbird
Procella\tP610
Procella\tP8
ME Geithain\tRL 801K
Adam Audio\tS3X-V
Axiom Audio\tM50
PMC\tBB5
Dynaudio\tM2
Axiom Audio\tVP160
Seaton \tSpark
Coincident Speaker Tech\tTriumph Extreme II
Axiom Audio\tM22
PMC\tMB2S
ElectroVoice\tZX1
Genelec\t1038CF
Tannoy\tDefinition Install DC8i
eD\teD[c]6
Paradigm\tCC-390
Klipsch\tRB-61
Axiom Audio\tM3
JBL\tStudio L890
K+H\tO 410 Studio Monitor
Triad\tInRoom LCR Gold
Genelec\tAOW312B
JBL Pro\tLSR4326P
Ascend Acoustics\tCMT-340 SE
Tannoy\tDefinition Install DC6i
JBL Synthesis\tLs 80
KRK\tExpose
Paradigm\tCC-370
Paradigm\tSignature S8
Hsu Research\tHB-1 MK2
Hsu Research\tHC-1 MK2
SVSound\tMTS-02
PMC\tIB2S
Energy\tRC-10
Reference-Capable-Speakers.pdf 442.220703125k . file
Add Power Sound Audio MT110 @95DB, MTM210 @98DB
Huh, not a single KEF or Revel speaker eh?
What models that Kef makes do you feel are high sensitivity. I am not aware of any of kef's speakers being high sensitivity. I don't think Revel makes high sensitivity speakers either. Both companies make speakers that can handle a lot of power, but they are not high sensitivity. Both companies make excellent speakers also.
I didn’t think these were missing necessarily, was just a bit surprised that the big Revels or KEFs wouldn’t make it!
Kef lists the Blade, Blade 2 and Muon as 90db sensitivity. Revel lists the Salon 2 at 86.4db. Also not high sensitivity.
I dunno... the spreadsheet seems to indicate that 90db is perfectly acceptable for this category. The new Revel Be line hits at 90db. (328's - 91db; 228's 90db; 226's - 90db)
Premium Member
You kinda do have a point. Its been a few years since I looked at the spreadsheet and some new entries at the bottom are not exactly high sensitivity. Maybe medium? But by some program watt metrics of the sheet they make it.
I do not consider a speaker with 90db a high sensitivity speaker. Nor would I consider 93db as high sensitivity. I think you need to be above 95db to be considered high sensitivity. 90 to 95db is good sensitivity, but would not call it high sensitivity. I consider anything in the 80's as low sensitivity.
I suppose it is a moot descriptor since the question is: will it play at reference levels? I don't know the answer about the goldenears but I suspect someone can sort that out!
Premium Member
Eyleron the OP could sort this all out. Unless its a horn loaded design with a CD or a ribbon most soft domes can't play nice at reference levels unless it can handle and is given a lot of power. Desings with multiple soft domes can work. This is just a generality tho.
I haven't seen any industry standard for differentiating between low, medium or high sensitivity/efficiency speakers so there are going to be different interpretations that make it hard to reach agreement.
Gary Garrison's set-up
What's SPL mean? And can I make a 5.1 surround setup with any of these for less than $1000?
SPL means Sound Pressure Level, and it refers to actual, physical, measurable sound intensity in the room, at the location where it is measured. It is the real thing. If you were to ask a physicist, "How loud is it?" the answer might be in dB SPL. If you were to ask a psychologist, the answer might include that "loudness" is a perceptual phenomenon and judgement of loudness depends on many things: amount of distortion in the sound, room acoustics, and that we hear bass and high treble more softly than midrange, even when they are at the same SPL.
I think it would be very difficult to put together a reference level capable 5.1 system for $1,000. I could be wrong, of course. See the prices listed in the chart.
In answer to other questions, I would think high sensitivity speakers would be 95 dB/1w/1m and above. Most would be above.
THX reference specifies 85 dB continuous sound level at the listening position with 20 dB of dynamic headroom to allow for 105 dB peaks in the program material. Distance from speaker to listening position is a factor. For example, Kali Audio rates their active speakers for maximum listening distance to reach reference. The LP-6 is rated for 85 dB continuously with 20 dB of dynamic headroom at a maximum of 2.2 meters (7.2 feet) while the larger LP-8 is rated at 2.8 meters (9.2 feet).
So for starters you would need to know the distance from your proposed speaker system to your proposed listening position. Then you could begin narrowing down which combination of speaker efficiency and amplifier power would be required to reach 85 dB continuous and 105 dB peak at that distance. Finally you could calculate the prices of different setups to narrow it down to those that fit your budget. For example, a smaller room with shorter distances between speakers and listening position would require a less capable and less costly system to reach reference.
If you plan to listen at more modest levels than reference then even less capable and less costly systems can work.
I'm gonna jump in and say, the Electrovoice interface C and D are contenders for sure. Easily outpaces some of the big and rare cerwin vegas i've had before
It seems this spreadsheet is outdated and no longer maintained? Is that true?
I came here looking for information on speakers that have a general consensus for having excellent performance and value in some way or another. Is there another thread with a list or spreadsheet that can help me with this?
I will be building a new theater later this year. I would not say that cost is no object, but don't have a specific budget. But I'd say probably a hard limit of 5k for front stage, and 5k for all other speakers (excluding subs). I just want high end performance for both music and movies. I currently have a Yamaha RX-A3060 and a 7.1.4 where all 11 speakers are 8" 2-way Yamaha in-walls, and 8x 18" Fi IB318 in manifolds in the ceiling. I may keep the subs, but I want an upgrade on the speakers. I may also add GSG 21" Martys to handle everything from 30-150 hz, and run the IB system from 30hz and below.
Anyway, I want a fantastic sounding front stage. I thought about KEF LS50, but I'm not sure they would have the output for theater that I'm looking for. I thought about building a pair of open baffle speakers using something like Acoustic Elegance drivers and who-knows-what for the HF. I'm just looking for options.
