Status
Not open for further replies.
1 - 1 of 1 Posts
Today I got my 1251q for the tubes. I am replaceing the burned ones in my 1270q that I picked up awhile back.
Everything went very well, but on the tubes from the 1251q, the 2-4 poles on the neck were different. I went ahead and installed them, everything fires up right, no fire or lighting bolts flashed from the tubes... I had it on for about 1 hour and seems ok.
I guess my main question is, is there going to be a difference in setting up the tubes now that there are different looking poles ? I turned the ones on the blue and it did move the test pattern right to left fine...
oh and maybe someone can recall how to reset all setting back to factory, I looked in my manuals and did a search but came up blank.
Thanks guys,
Brian
1 - 1 of 1 Posts
Status
