1 - 1 of 1 Posts
I have a htpc with windows 7, ati 4770 graphics card, amd phenom ii 550 dual core turned into quad core but have tried both ways. This is kind of hard to explain but when I start up the computer everything is fine but right after windows 7 loads my windows 7 screen should just be there but before i see my windows 7 screen I see some little green lines across the screen then it turns black then i see the windows screen for about a second then i hear a kind of loud pop then the sound comes on. That can't be normal right? Some times when windows 7 starts up instead of a normal little chirpy tingle sound I hear like a jet engine sound that does not go away..???? I have downloaded the newest driver for the graphics card. I am using a dvi to hdmi adaptor that came with the graphics card. If anyone can give me any ideas on what is making this system start up wierd that would be great. Thanks
1 - 1 of 1 Posts
