FPTV folk have a dilemma. Do I make the vga run to the projector long and keep the s/pdif run to the preamp short?
Or do i make the s/pdif run to the preamp long and keep the vga run to the projector short?
Given that vga is analog, I guess that the vga run should be short to avoid side effects (how short is short anyway?)
That means that the spdif run should be the long one (how long is long before you need a repeater anyway?).
My dvd player has toslink out, so I guess i need a convertor. Is there a quality difference here that makes any difference or will a radio shack one do? you know, toslink to coax.
Stefan
Stefan
