Status
Not open for further replies.
1 - 4 of 4 Posts
I'm converting our family room to an HTPC. The PC will be about 25' from the HDTV (Hit 43FWX). Using a Radeon 9000 Pro and AA9A60 (VGA > YPbPr). Best to run a long VGA cable and convert close to the HDTV or convert at the HTPC and run a long YPbPr cable?
Aslan...
For a 25' I really would recommend a really good VGA cable. No the cheap ones that you can buy in a computer store, they normally don't even have 75 ohm connectors.
Yes
1 - 4 of 4 Posts
Status
