Status
Not open for further replies.
1 - 2 of 2 Posts
You will need 75 ohm for the video and that will also work for audio.
You can make your own if you like. Go to Markertek and check out the Canare LV-77S coax. They also sell the 75 ohm crimp fittings for RCA and BNC which should handle all of what you need.
Of course you'll have to invest in the Canare coax stripper and crimp tool with the appropriate die, but you will end up with the best cable for far less than a bunch of Monster or other stuff.
Also, once you've invested in the tools, you can whip up a cable of any length at a moments notice.
I bought the tools a couple of years ago and they've more than paid for themselves.
Hope this helps,
Phil
1 - 2 of 2 Posts
Status
