It's a odd room and the best solution looks like a ceiling mount is our best option.
It will be professionally installed by our contractor, into reinforced joists, through and through bolts. I just have to find a mount. I see alot for 55 inches, 63, but none for 65. I'm sure it would work but I'd like to also add a sound bar as well.
I'm looking at the outdoor mounts of the double sided mounts now, but they are quite ugly.
Budget it about $1000.
Edit. It would be nice if it swiveled and tilted. Would be super nice if it went up and down. However no motion is fine too.
