1 - 9 of 9 Posts
What Im looking for is a quality 5.1 Dolby Digital (DTS, HD, etc..) surround sound system for no more than $1000, less if possible. Now this does not have to be 100% all-in-one, it could be a set of speakers and a recommended receiver.
Thanks for all your help!!!!
Is there a size limitation on the speakers? Can you have towers?
If so...
Energy C-300s up front
http://www.audioadvisor.com/prodinfo.asp?number=ENC300
Energy C-C50 center
http://www.wwstereo.com/#/ecommerce/..._84__0_0_0_-1/
Energy C-50 surrounds
If you can only have bookshelf speakers, get the C-50 5.0 package
Add a quality subwoofer
And you'll still have $450 for a receiver
http://www.newegg.com/Product/Produc...82E16882120146
Discussion Starter · #8 ·
afrogt, I think I'm going to go with your first suggestion as tower speakers all the way around can we more difficult. I can just either hang, or put on stands the smaller surround speakers. Thoughts?
1 - 9 of 9 Posts
