1 - 4 of 4 Posts
· Registered
You might want to check out these 2 as possibilities then.
http://www.directron.com/rs600ambad3.html $100
http://www.directron.com/rs700ambad3.html $103
Cooler Master has the Silent Pro M 600W and 700W versions. I was thinking the 600W might be perfect for a HTPC, but after checking prices it seems you can have the 700W version (though there might be a slight more power draw) for about the same price at Directron.com. Anyway, read a couple reviews last night and here's sone of the favorable reviews. Made to be silent with a 135mm fan and silicone pads.
http://www.virtual-hideout.net/revie...0w/index.shtml
http://www.ocia.net/reviews/cmsilentprom600/page4.shtml
http://www.topreviewshop.com/cooler_...pro_m_600w_psu
http://tech-reviews.co.uk/reviews/co...ennt-pro-700w/
· Registered
What kind of HTPC are running that needs 600W of power?
· Registered
Yeah, Corsair can be had on newegg for less than 50 with a rebate and free shipping.
If you don't want to deal with a rebate, you an try a Seasonic for around that same price.
And if your components do need a 600W power supply, then I would rethink those components.
1 - 4 of 4 Posts
