Status
Not open for further replies.
1 - 3 of 3 Posts
Hello,
I'm looking into building HTPC for my family room, that means, that it should be very easy to use ...
so, I'm looking for a remote control with a touch-screen , palm ? ... and under $50 or so ... it shouldn't be anything fancy , but it should be good to program
thx :)
Good luck getting a touch-screen for under $50. The 1MB Prontos are probably selling on fleabay for $100+.
The best place to start is Remote Central . They'll be able to find you a remote for around $50 that might suite you better than a touch screen.
IMHO, you should spend the extra $$ and get the Pronto.
1 - 3 of 3 Posts
Status
