Hi all,
I've decided I'd like to try making my own sub. I've started doing some reading, but wow there is a lot of information. So I was hoping for some advice on what to build! I had a look at the list of DIY projects but there are so many of them!
I'm looking for something easy to build, not too complicated - preferably something with detailed step by step instructions and exact measurements!
I'm good with either sealed or ported. I will likely look at getting an inuke NU1000DSP. I won't be pumping reference movie volumes out of it, and I don't need lower then 20Hz out of it. I just want flat, tight bass from it.
I live in Canada. I'd also love a suggestion of an available driver that would go with whatever build is recommended.
Any advice is appreciated! Thank you.
