Hello everyone,
I used to be very active here back when I was heavy in love with Home Theaters.
Now, years later, I have settled down and am now looking for some advice on the best hardware for my situation. I hope you guys can help me out.
Background:
We currently rent a house in Germany, so there is no way of changing cables (some light switches need 2, some 3 phases) or opening up walls etc.
I want to build a home automation system that is not dependent on the manufacturers cloud or app. Who knows how long which manufacturer will support a device or even be around for. So I am setting up a Raspberry Pi with something like Home Assistant or OpenHAB (not decided which yet). Therefore the devices should be usable without cloud service etc.. I don't mind using a cloud to get an initial token or something, but ideally the devices are compatible to IFTTT or MQTT or whatever.
I do not want dedicated hubs for each manufacturer.
Criteria
Needed hardware/functions:
Why I don't want to buy plug-in power outlets? They don't look nice.
Why not Philips Hue or other smart bulbs? The are wasteful. I don't want to throw away the electronics just because a light bulb dies. Nor do I want to add a new bulb to my system just because a bulb broke. Apart from that, I find it much more flexible and future proof to make the root smart, i.e. the power supply rather than the backend.
I hope you can help me out with some advice. Please feel free to point out any problems or things that will strongly increase the price. If a light switch costs 10 times more because it is 5 Ghz rather than 2.4 Ghz, then screw it, I have 2.4 Ghz devices (washing machine etc.) anyway.
Thank you all and best regards
Alex
Background:
Criteria
- Not dependent on manufacturer support (so usable with open source plattforms like Home Assistant or OpenHAB.
- Retrofittable. Ideally behind existing light switches /sockets rather than replacements. This is better because the design of the smart and non-smart outlets and light switches will remain unchanged then.
- No batteries. I don't get why any device that regulates power like a light switch or outlet would need a battery. It is connected to the grid after all.
- No problems with ripple control signals. I have read that the Shelly Dimmer 2 handles these very poorly, resulting in flickering lights, and it seems there is no proper fix for this.
- Preferrably 5 Ghz support. Not sure why so many devices still use 2.4 Ghz. It's okay of course, but unless it increases the cost, 5 Ghz would be nice to have.
- No need for additional hardware (so no Zigbee or Z-Wave). Should use Wifi or Bluetooth (Wifi preferred).
- Light switches. I am thinking about stuff light dimmable, but I think I will stay with binary on/off. I don't use any dimmers right now and I usually pick the light bulb for the location.
- Power outlets/sockets.
Alex
