I would like to start off with saying that this is my first DIY audio build and I am really looking forward to learning and exploring the various aspects of DIY audio. It is truly amazing to see what you guys design and build.
For my first build I would like to try a sealed subwoofer. Originally, I bought a ported eD A5-350 and I just didn't feel like it fit well with my system. With a little encouragement from another forum member I decided to look into building a nice musical sub that would integrate well with my Vandersteen 2Ce Signatures. What was suggested to me was a AE 15-X based build in a sealed box driven by a pro amp.
I am going to be using this sub for a 50/50 mix of movies and music. Even though it will be used evenly for music and movies, I would like to focus on musicality.
My room is 25'x12'x8' and my seating position is about 8' away from my speakers. I played around with room placement using the eD sub and found that with my limited placement options, the best spot for it is right next to my mains in front of my seating area. This causes somewhat of a dilemma in that I don't want something monstrous that will stick out into my walkway or look out of place. The size of the enclosure that has been suggested to me is a 18.75" cube. If this is the correct size, it would work out well with the limited room I have.
I am working on a limited budget so I have been piecing together the items I need over time as they go on sale or I find them second hand. So far I have:
- AE 15-X driver
- Behringer EP4000 amp
- Behringer BFD
- 4'x8' piece of 3/4" Cherry veneered plywood
What I know I still need:
- Cabling from the amp to the sub (thinking of speakon connections?)
- Internal cabinet wiring
- Cabinet feet
- Polyfill
- T-nuts and screws to hold the driver in place
- Glue or epoxy
Is there anything else I am missing?
I have a friend who is a professional kitchen cabinet maker who is going to help me with this build because frankly my woodworking skills are horrendous. He should have all the tools we need to build it but I need to find out how to do this correctly. I'm guessing there are some differences between a kitchen cabinet and a speaker enclosure.
From what I've noticed, it seems that just about every build and builder designs and assembles their cabinets a little differently. Are there any general rules that I should follow when building this?
For example:
Is there a certain joint style that I should use for the corners? I would like to make it look as nice as possible while still being strong.
How about glue? I see some people use a good quality wood glue while others use a two part epoxy. Which is better?
Should I support the magnet with the internal brace?
As far as wiring goes, I am looking at using speakon connections. They seem to be rugged and fairly inexpensive. Will the two pole connectors work or should I use four pole? It looks like the four pole style are a little more common and will give me greater flexibility.
I would like to get most of my supplies ordered this week or early next week so I can get a start on this build soon. Any suggestions for good parts suppliers would be very welcome.
Sorry for my many random questions but I want to make sure I build this correctly so it can last me a long time. Any tips, suggestions, and links to more information would be greatly appreciated.
- AE 15-X driver
- Behringer BFD
- Cabinet feet
- Polyfill
- Glue or epoxy
For example:
