One very simple thing you can do to stop your CC speaker from "dominating" the others is to go into the speaker set-up menu and lower its level by a couple dB or so.
The obvious (and free) solution would be to lower the trim level on your center...have you tried it at -3db, for example? There is zero reason to stick to your current trim levels just because Denon's room correction tool set it that way---they are notoriously 50/50 at best.Hey all,
I am currently running a 3.2 setup in a small space but moving to a bigger house so thinking of changes. Currently, I feel with my setup that the center channel really "dominates" the L/R front speakers. The sound is clear and in movies I do get nice clear voices but I get that feeling that all the sound comes from that 1 speaker. When I listen to the front L/R the sound is very faint or minimal. The Denon receiver is usually set to Main Vol 56 (98 is full-max)
I have my Fronts and Center set to small and the crossover at 80hz. The front left/right is set to 0db and the center is set to +1db. I measured distance from each speaker to my main seat and it is 9ft and 8.5ft so those are set up as well.
This.The obvious (and free) solution would be to lower the trim level on your center...have you tried it at -3db, for example? There is zero reason to stick to your current trim levels just because Denon's room correction tool set it that way---they are notoriously 50/50 at best.
The more I am reading the more I keep seeing this, and I def knew that dialogue was controlled by the center channel, I just thought more sounds or effect would come from the front L/R. I keep wondering if hey even doing anything to improve the sound field. like if just killed the L/R would it still sound the same with just the center and a sub 9now i'm essentially in Sound Bar territory essentially).The other side of this equation though is the center channel is supposed to be doing most of the sound during a movie. Turning it down will reduce the dialogue volume. But give it a shot.
Actually many streaming services offer ATMOS if you have hardware capable of receiving it.(Netflix, Prime, Disney+, AppleTV+, HBO MAX) I also would not recommend ATMOS enabled speakers. If you own the home then by all means invest in on ceiling or in ceiling speakers. Four ATMOS speakers are a lot better then two. Your current receiver of course only supports 5.x.2 but wire for four assuming future upgrades.The more I am reading the more I keep seeing this, and I def knew that dialogue was controlled by the center channel, I just thought more sounds or effect would come from the front L/R. I keep wondering if hey even doing anything to improve the sound field. like if just killed the L/R would it still sound the same with just the center and a sub 9now i'm essentially in Sound Bar territory essentially).
This is why I think I want to get more of a true setup in my new place and move to Atmos since my AVR supports it and just move the current fronts to the rear and buy Floor Standing Atmos speakers, the flip side to this is I hardly ever watch Blu-ray and I don't own the newer 4k Blu-ray players, 90% of the movies I watch are Streamed (Netflix, Amazon, Hulu, Disney+ etc) So I probably won't ever really benefit from Atmos unless I and watching something that is broadcasting it and I don't think any streaming service is offering it. Would I see any benefit at all from the setup in that case?
How far apart are your left and right speakers? Maybe bump them up a couple dbs instead of lowering the center. Skip the up firing speakers. I have just 2 speakers mounted on the walls near the ceiling to the left and right of the listening position and it works pretty good. Not as good as a full Atmos setup but it makes a pretty big difference in many movies.The more I am reading the more I keep seeing this, and I def knew that dialogue was controlled by the center channel, I just thought more sounds or effect would come from the front L/R. I keep wondering if hey even doing anything to improve the sound field. like if just killed the L/R would it still sound the same with just the center and a sub 9now i'm essentially in Sound Bar territory essentially).
Yes, Audyssey settings are anything but infallible. Always use them as a STARTING POINT only, and manually tweak to YOUR tastes.I only do the Audyssey setup, but I understand from the above that this is often wrong?
The Left and Right speakers are currently roughly 7.5ft apart.How far apart are your left and right speakers? Maybe bump them up a couple dbs instead of lowering the center. Skip the up firing speakers. I have just 2 speakers mounted on the walls near the ceiling to the left and right of the listening position and it works pretty good. Not as good as a full Atmos setup but it makes a pretty big difference in many movies.
Yes, "height" speakers are considered the next best thing if you can't do in- or on-ceiling.Does having them mounted higher sound better then the up-firing ones bouncing off the ceiling? I ultimately don't want to go through all the effort in the new place if the sound will end up similarly sounding.
