Status
Not open for further replies.
1 - 4 of 4 Posts
Premium Member
I now need of a DIY ceiling mount for my AE100 LCD PJ setup.
Just looking for pics and info about the two way adjustable dealy that I could use to mount the projector to the ceiling with.
I plan to:
1) mount the projector to a board.
2) mount a two way (up/down - left/right) adjustable pivot
3) attach a pipe to go through a drop ceiling tile and mount to a 2 x 6, 2 x 8 or a peice of plywood. Basically mount through the wood.
Any hints or tips on making this easier?
thanx
Premium Member
Discussion Starter · #2 ·
Ok. Tried the search and this time I found lots of good info. Weird. Last time I got nothin. I now have pretty well all I need to know in order to go about making a ceiling mount myself.
If you have any cool pics or updates to your setup, feel free. Anything like the AE100/200/300 or other projectors. The AEx00 lineage is the best cause the mounting is the same :)
thanx for any info :)
Here is my mount that I adapted from MonkeyMan's design. I had to redesign it out of necessity. My area doesn't carry any M4 bolts long enough. It doesn't have side to side adjustment, but that wouldn't be too difficult to do, I wouldn't think.
Picture 1
Picture 2
Premium Member
Discussion Starter · #4 ·
Cool. Anybody else with examples of recent DIY mounts for AE x00 PJ's?
1 - 4 of 4 Posts
Status
