Almost identical performance to the HSU VTF2
Cons: down roughly 1-2db in overall outputs,
Pros: better build quality/finish/bracing.
So better than a pb1000 in every area.
Better upper bass 30hz and up than the pb2000 but not as strong below 30hz.
Still usable output down to 16-17hz.
I've spent $2600 so far so people calling me a tire kicker are being unfair, but what is roadblocking me from even knowing which sub models to start comparing and narrowing down at this point is all the posts, before I mentioned my big space and tile floor, saying that bass works like water, and you need to pressurize the room, and that that is the biggest reason why a $300 sub wont do it, and I need to go to $500-$600. But then after I mentioned my tile floor, most aren't even answering what I need to do, the only two people to have addressed it said $500 will no longer cut it to pressurize the room, but didn't say what would, and another saying it's not possible to do.
So if it's not possible to do, then maybe I'm better off going back down to $300, since one of the main differences between $300 and $500 no longer applies? Plus no one answered me how loud it would be, and I may not want it super loud, I mean I definitely dont want it shaking everything or hurting my ears or bothering neighbors, but maybe those arent worries, no one has explained what the noise is like. But if $500 ones are super loud, maybe I dont need that.
On the flipside, it's not too loud, maybe there is still a way to pressurize the full space, if I go up to $750, or look for something used? I think I can get two starke sealed 12s or 15s for $600 or something.
Product Details. There are the 10s for $500 but he said 15s for $599 I think, have to go back and check. No one has told me if that would do it or not.
I'm not a tire kicker, but it's impossible to make an informed decision with so much missing information, and changing information. A lot of helpful posts were given, but no one thought to ask what kind of floor I had, and I'm too newb to know it was relevant, until after most of those were made, making most of those posts potentially obsolete in many ways, depending on what's possible with that type of floor.
Then everyone got mad like "we already helped you." Yes helped me find subs to use with either a normal or small room size, or a normal floor, or both. It turns out I need help finding subs to use in a big space with a tile floor, and by the time I or anyone else knew that, some posters abandoned helping me, told others to do the same, called me a tire kicker, etc. So that's where I'm at and why. I hope the explanation makes people see the situation differently, how it was from my shoes, and please reconsider helping me get over the finish line.
I already spent $2600, and I will absolutely buy a sub. I'm not a tire kicker. Just am stuck because of the floor issue.
