Status
Not open for further replies.
1 - 20 of 20 Posts
Anyone have a suggestion on where to buy sconces? Ive looked at a ton of places online, but the wife and I cant seem to come to an agreement, which is pretty typical :). Im not interested in the the ones that say like cinema or have popcorn or what not....just something nice to put on columns for a little ambient lighting.
Have you checked your local sources like Lowe's, Home Depot and local speciality Lighting Stores?
Discussion Starter · #3 ·
yeah weve looked at HD and Lowes...we found some that were ok if you catch my drift...nothing great....I guess Im not even sure what Im looking for....I'll know it when I see it I guess..of course trying to stay in a reasonable price range has its effects as well.
Got mine at IKEA, check out my gallery for a picture next to the exit sign..I hae 5 around my basement controled by a dimmer from HD.. hope this helps you.. Matt
Another vote here for lampsplus and homedecorators..
Although with Homedecorators, I go to homedecoratorsoutlet.com as I think their normal site is too overpriced. Most of their stock eventually seems to end up in the outlet. I watched my $279 bar stools forever before I bought them for $79 each on the outlet site.
Discussion Starter · #9 ·
Taxman....saw something similiar to these at Lowes yesterday. They appear to be a little wider than yours but the same design. They came in 2 or 3 finishes, around $60...what did the ones at Ikea cost if you dont mind me asking?
lamps plus
Discussion Starter · #13 ·
Yeah my wife doesnt like the paintable ones, but thanks for suggesting it....I think I have found the ones that I am going to get, but havent finalized my decision yet. Found them on ebay
I use the paintable ones in my office, but I do find they don't put out a lot of light since the sconce itself is opaque. Just an observation I found.
DFord42: they cost $20.. company is called "Strimma" and you could find them on the IKEA website.. I have the one by the exit sign, wired with a pull chain, the rest are on dimmers
I would look at putting them between the columns rather than on the columns. And pay special attention to the pattern that they throw. When installed, that will be as important to the look as the fixture itself.
Discussion Starter · #18 ·
Defintely going on the columns, not in between, dont like that look as much as on the columns. I found ones that I believe I am going to purchase. Found them on ebay. A little expensive, but sometimes you just have to pay for things you like. THanks for all your input.
Also, having them on the columns, you can benefit from not having big holes in your room's shell. Feed the romex through a small caulked hole and have the box on the column.
Dan
I'm currently putting the finishing touches on my new house and home theater room. Today I placed an order at Lampsplus for the following sconces: Sconce 1 (Flanking my Projector screen) & Sconce 2 (General room lighting) . For anyone who's planning to purchase from LampsPlus, google "LampsPlus Promotional Codes." I was able to find several coupons like the following:
$20 off $100 purchase
$10 off $50 purchase
$25 off $250 purchase
See CouponCabin for details. I don't know what made me think to search for coupons but I'm glad I did. Just thought I'd pass along the savings...
-Jeremy
1 - 20 of 20 Posts
Status
