1 - 20 of 35 Posts
Hi All,
I know, I know, Bose sucks. I got suckered into buying these from a Best Buy rep a while back. Well, two weeks ago a pipe burst and my home sustained heavy water damage. My speakers and sub got water from above as well as my Vizio tv. Insurance wants me to send speakers and tv in for water damage testing, but I can't find a company that will do it in my area, which means I would have to find boxes and ship to the manufacturer. At this point I'm fed up and may just give up with the insurance and buy new equipment on my own. It's funny how the adjuster saw Bose and said he had Bose at home and sounded proud, while I was ashamed.
The question is what should I replace the front, center, and sub with? I'd like to stay somewhere around the range of $300 for Front $150 for center, $150 for sub). I used these primarily for watching movies and may make the 301s - If they still work - the rear speakers.
My current setup:
Receiver: Denon AVR-791
Sub: KLH KSUB-10
Front: Bose 301V
Center: VCS-10
Rear: Bose 161
Vizio 42'' LCD TV.
My room is kind of large (25' L x 14' W, but not great for acoustics (lots of open spaces, rectangular, loft style)
Thanks for any and all suggestions in advance! And if anyone knows how to navigate the insurance nightmare and has any tips I'll be very grateful!
+1 mark62's lower budget recommendations - the Cambridge Audio or HTD Level 2 speakers (both slightly under your budget) with the Dayton Sub.
If you can spend extra on the sub the SVS PB-1000 he mentioned would be a very noticeable step up.
For the HTD Level 3 speakers budget range there are a couple of other options to also consider ...
- The Arx A1b (you can use either a 3rd A1b as a center, they're sold individually, or the A2rx center speaker)
- The Ascend CMB-170 (if you call Ascend they will typically sell a single 170 for a center, or you can use the CMT-340 center)
All the speakers mentioned are good choices and commonly recommended at their price point here in the forums. And all would be a substantial improvement over your old Bose system
Originally Posted by sdg4vfx  /t/1513640/looking-to-replace-bose-after-10-years-and-water-damage#post_24254953
agree on the Arx and ascends +1
and yeah his jaw would drop to the floor with any of these compared to Bose
Discussion Starter · #6 ·
Thanks to everyone for their input! I have seen the reviews for the Cambridge Audio S30 somewhere around here. Does anyone know if the Cambridge SX50 or even the SX60 is a better choice?
Originally Posted by carlos.h  /t/1513640/looking-to-replace-bose-after-10-years-and-water-damage#post_24256238
They do not look, or seem to be better - and not as smooth as the S series.
That is based on a couple of comments.
From everything I'm seen so far, there's no real reason to go with the SX over the S30 unless you can get on sale for cheaper as it seems people somewhat prefer the S30 over them.
And I'll give a +1 to all the suggestions listed too, and give another choice with the HSU HB-1 MK2
Originally Posted by ien2  /t/1513640/looking-to-replace-bose-after-10-years-and-water-damage#post_24256288
Originally Posted by zieglj01  /t/1513640/looking-to-replace-bose-after-10-years-and-water-damage#post_24256282
+1 Esp. now that the S30's are on close-out prices at accessories4less. Just make sure you get your center now since the S series in end-of-life. FWIW, if it were me I'd probably skip the S50 horizontal center and get an additional pair of S30's - use one as my center (upright since they're only 9" tall) and then have an extra for backup, or use it as a "back" speaker for a 6.1 setup.
I'm considering the Ascend CMB-170 for a 2.1/3.1 system. How do these perform for movies in terms of dialogue/voice with regard to clarity? I already have a sub so I don't need them to hit too low. I'm looking for midrange and clarity.
Originally Posted by JoeBloggz  /t/1513640/looking-to-replace-bose-after-10-years-and-water-damage#post_24256617
they are highly regarded speakers. they should be very good. try them out, if you dont like them send them back.
what is your sub?
Clarity and detail would be considered CMB-170 strengths by most people, esp. in the vocal ranges. As mark62 said "try them out, if you don't like them send them back".
All the speakers in your thread so far are often recommended, best-bang-for-the-buck at their respective price points
Originally Posted by mark62  /t/1513640/looking-to-replace-bose-after-10-years-and-water-damage#post_24256629
what is your sub?
Yeah it'll be movies/TV and music about 50/50. I'll add a center later on. My sub is budget too, Polk PSW10. I haven't used it with receiver(which I'm getting soon too) yet, so I hope it'll be a bit better. I'm saving up for a PB1000(hopefully they go on sale sinnce the 2000's are out now).
I just wanna add things as I go so I can get something decent in the end.
I just hooked up 3 CBM-170's across the front and 2 HTM-200's as rears in my parents' basement and they sound great. Would certainly recommend them to others. Those with the Denon e300 and Audussey seem to be a good setup. Now I need to update their old KLH sub.
what is your sub?
Originally Posted by sdg4vfx  /t/1513640/looking-to-replace-bose-after-10-years-and-water-damage#post_24256656
You guys aren't making this any easier
:p I'm torn between a few. HVL-1's, CMB-170, CA S30, NHT classic Two, Def Tech SM45! I'm ready to just go the eeni-meeni-miney-mo route
:eek:
Originally Posted by JoeBloggz  /t/1513640/looking-to-replace-bose-after-10-years-and-water-damage#post_24259114
:eek:
I have not listened to the HVL-1 or CBM-170 > however, I would lean towards the CBM-170
Now to make it easier - between the CA-S30, NHT-C2 and SM-45 > I would choose the JBL Studio 530
Originally Posted by zieglj01  /t/1513640/looking-to-replace-bose-after-10-years-and-water-damage#post_24259171
I've looked at those but they're too tall(18") for my application, which is on media cabinet under TV.
Originally Posted by JoeBloggz  /t/1513640/looking-to-replace-bose-after-10-years-and-water-damage#post_24259321
Well then - to continue to make your decision easy - my preference over the
Studio 530, is the Boston E60 >> a serious good speaker, and use to list for
$600 each
http://www.amazon.com/Boston-Acoustics-E60-Performance-Bookshelf/dp/B001H9O1CQ/ref=sr_1_1?ie=UTF8&qid=1390584533&sr=8-1&keywords=bOSTON+E60
Enjoy the adventure - you do have some nice options
Originally Posted by zieglj01  /t/1513640/looking-to-replace-bose-after-10-years-and-water-damage#post_24259476
$600 each
Thanks. That price is each, correct? Also do they NEED stands? For me they will be on media cabinet.
:eek:
The HVL-1's are designed by the same guy that does the Ascends.. they may be a great bang for the buck....
1 - 20 of 35 Posts
