I have HTPC (nvidia GTX660) connected to a Emotiva UMC-200 and then out to a Sony HW50ES projector. I get sound and video but I lose some of the functionality of the projector. The projector sees the signal as 3d and turns the lamp brightness to high and no iris function. If I force the signal to 2d in the projector, I can then turn the lamp down but no auto iris or simulated 3d functionality. If I connect the HTPC directly to the projector, then all functions return. If I run a blu ray player through the UMC-200 and out to the projector all functions of the projector are also good. I should be able to set the projector to auto 3d (meanig the projector determines whether to set 3d or 2d), but then the problems return. This has to be a problem with either the UMC-200 or the projector, since there is no problem with a direct hdmi connection from the HTPC to the projector.
I have been pulling my hair out the last 2 days trying to figure this out. Sony is no help. They just say that if the signal is good going in to the projector it will function properly. Something must be happening to the hdmi video signal while it is in the UMC-200 to make it look like a 3d signal or something.
Anyone have any experience with this?
