Ok...I am starting to look into purchasing a projector and screen.
1. What specs should I be looking for?
2. What are the differences between the DLP, D-ILA and LCD projectors? Which are considered the best or what are each ones strong and weak points?
3. Would I want a progressive DVD player or a HTPC? I currently own the JVC723 progressive scan. Would I only notice a difference on a larger screen or could I see a difference on my current 55" HDready TV?
4. If HTPC, what would I need to hook it up to a TV or projector?
5. What are some good projectors for the price? Let's say in the $3000-$5000 range and then $5000-$10000 range.
6. Are there any good internet sites that sell projectors, screens, HTPC equipment?
7. Do certain HTPC equipment or DVD players add to edge enhancement, over saturation, and/or chroma problems?
Please feel free to answer any or all of the above questions?
