Status
Not open for further replies.
1 - 3 of 3 Posts
I have two STBs, the DTC-100 and a Panasonic. Anyone else have two and hear an audio volume difference between the two. Is the DTC-100 louder than most? Is there any way to adjust volume out from any of the STBs?
What I have noticed is that the level of the analog output is higher that the level of the digital output. Overall, it seems a little louder thatn any of my other sources using the analog output. Using the digital output it seems the same as others.
Bill Milford
Now available to the highest bidder!
Premium Member
My DTC-100 is a good 6 db louder than my E*6000, and Panasonic DST50 which is fed to a Techniques SHAC500 decoder. I only use the optical outputs on all the receivers. I also have the dish 5000 but it is output via 8VSB and fed to the DTC-100, therefore it is also louder as a combination.
Don Landis
Home Theater Pics at: www.scubatech.com Last updated 3/25/01
1 - 3 of 3 Posts
Status
