FYI. I just purchased 6 Aura Interactors (back pack worn for gaming, etc.) which use the Aura 18 Watt Bass Shaker. The system comes complete with amp and shakers. I originally was considering the Pro Bass Shakers, but came across the outstanding buy that I could not pass up. I purchased the Interactors and was not sure if they had a high enough force output, etc. I disassembled 2 Inteactors to remove the shakers. I mounted 2 under the couch and used the 2 included amps set to music and fed in the LFE signal. In short I am pleased with the setup. The amps are class B and one could consider a better amp, but is an explosion with 2% distortion noticeable? Obviously one could use any amp they might like and your mileage may vary. All in all for a total cost of …..
$53. I have Shakers and amps delivered and installed on my couch. The units can be purchased from: http://www.oshealtd.com/interact.htm
The only bad part was that two of the actuators were damaged during shipment via UPS (glue between springs and outer ring broke due to a drop I would expect). I am pursuing a claim from UPS, and having 2 more sent from http://www.oshealtd.com/interact.htm to replace the others.
Happy shaking
Gary
Happy shaking
Gary
