The WRGB OLED EDR for i1Display PRO users available in ColourSpace/LightSiace has been created from X-Rite + LightIllusion + FSI based on spectral samples using an LG OLED panel (FSI 55 OLED model).
How to get this WRGB EDR file?
1) For users with ColourSpace, this file EDR file is available here:
C:\Program Files (x86)\Light Illusion\ColourSpace\i1d3 Support Files
2) For users with ColourSpaceZRO, this file EDR file is available here:
C:\Program Files (x86)\Light Illusion\ColourSpaceZRO\i1d3 Support Files
3) For users with LightSpace, this file EDR file is available here:
C:\Program Files (x86)\Light Illusion\LightSpace CMS\i1d3 Support Files
4) For non-ColorSpace/LightSpace users, at @ LightIllusion General Download page.
Any of those methods are avaioable for CalMAN users to improve their calibration with CalMAN.
i1Display PRO users of CalMAN have only an RGB OLED table available, useful for Sony Broadcast RGB OLEDs only.
So CalMAN users with i1Display PRO can improve their calibration with CalMAN, using that free spectral correction file!
SpectraCAL C6/C6HDR/C6HDR2000 colorimeters use EDR with spectral data taken from FSI 65 OLED (LG OLED Panel) for the WRGB OLED table.
Both FSI 55/65 OLEDs use the same LG WRGB OLED Panel.
After the file replacement, CalMAN users will have to select OLED table to their i1Display PRO, but it will load the WRGB OLED table.
Using that method, CalMAN users will get better results compared to RAW XYZ selection.
I quoting Tyler to able to write specific instructions (or other users) about that file replacement or record a video on YouTube:
Download the WRGB OLED EDR file from LightIllusion -> General Download (select WOLED EDR)
Use your Windows Explorer and enable Hidden Items.
Go there:
C:\ProgramData\Portrait Displays\CalMAN 5 Home\Data\i1D3
You will see that file:
OLEDFamily_20Jul12.edr
Copy the name: OLEDFamily_20Jul12
Rename the FSI_XM55U_23Jan19.edr to OLEDFamily_20Jul12.edr
Paste the new OLEDFamily_20Jul12.edr and override here:
Using your CalMAN, select OLED for your i1Display PRO (not RAW XYZ)
If you have an EDR You could in theory just rename it to an existing one’s name and replace that one. They are stored in the c:/ProgramData/spectracal/xx directory.
InstructionsIn theory you could just rename the EDR to an existing name that is supported, And then replace that one with the renamed file.
Go there:
