The only one I can think of near $1500 is the Benq 7700, with zero offset. The Infocus IN76 is more money. The Sharp DT500 may be one.
Originally Posted by gwlaw99 /forum/post/0
Be careful of the 7700. It has bulb problems that no one has confirmed were fixed.
The DT500 has a 15% offset which would make the picture 2 feet from the ground with a 6 inch drop from the mount.
Originally Posted by bill1908 /forum/post/0
I believe the offset is closer to 8%
Originally Posted by Halveb /forum/post/0
The new Optima HD73 has an offset of around 6-7%
Originally Posted by davdev /forum/post/0
Can anyone recomend some DLP models that have a small offset. My ceiling is only 8 feet high, and I want to try to do a 116" screen, but many of the PJ's I have looked at have offsets such that the bottom of the screen would be too close to the floor.
I would like to try to stay in the $1500 range
Originally Posted by Zipplemeyer /forum/post/0
I thought the HD73 offset is going to be the same as the HD72 offset.
Moe
Originally Posted by augiedoggy /forum/post/0
how close to the floor is too close?? my 108" screen is 28" from the floor with no keystone and 8' ceilings (HD70 =28% offset) a 118" screen should still be over 20" from the floor.....? How about mounting it on a low coffee table shelf....then it would be close to the ceiling. (and you deal with the neck cramps from looking up)![]()
Where did you read this? I thought the HD73 offset is going to be the same as the HD72 offset.
Moe
I looked at the mits 100, and with a 35% offset, my screen would only be 17" from the floor, which to me is too close, especially for two rows of seats. If I could do 24" I would be a happy camper.
The HD70 would give me 21 inches, but that is not including any space lost because of the ceiling mount, which I figure would be another 5-6 inches.
I could go with a slightly smaller screen, but I really don't want to, especially if I can accomplish my goal with an LCD.
is that calculated at the stated 33% or actual 28%
28
Originally Posted by caesar1 /forum/post/0
If you really want DLP -- (believe me I researched this heavily) -- the lowest offset will be the Infocus IN76. Its at 16%.
I think I have pretty much decided to stick with LCD. I can deal with slightly inferior black levels, it allows for more flexible placement.
