1 - 3 of 3 Posts
· Registered
I am getting ready to wall mount my HDTV and have been reading up on how people are running power/cables to their wall mounted TVs. I have found the box(s) I need but I do have one question about running conduit.
I am going to use the following box behind the TV:
Arlington-TVBU505-1 (sorry, I cannot post URLs yet)
I want to run conduit (from searching it appears I want "smurf tube") between the two low voltage "holes" in these boxes since the insulation in my house is the loose stuff and I want to be able to change out the cables. However I cannot see how to secure the smurf tube to these runs without insulation getting knocked out.
I saw this at Lowes today:
Search for 132088 at Lowes website (sorry again)
However I don't know if I can just mount that inside the low voltage "hole" of the Arlington box.
Can anyone point me in the right direction or tell me what I am doing wrong?
· Banned
They sell these at Lowes:
They are by all the electrical boxes (most of them will be the blue ones). I know you want ones with the twist tabs for completed work, but I think they sell them there as well. They have the holes for conduit built in.
1 - 3 of 3 Posts
