I have a Crosley CR 78CD turntable that can be used with its built in speaker or attached to external speakers. The speaker outs are rated for 8 ohm/5 watts. Is it ok to use speakers rated for much high power than this? I have a set of 8 ohm/200 watt speakers and a set of 6 ohm/ 100 watt speakers and I'm wondering if either or both of these sets would be ok to use. I have hooked it up and tried it out with these speakers for a short time and the sound is fine but I have read some comments that suggest that over time powering speakers with a much weaker power than they are rated for can be bad, is this true?
Also, is there such a thing as a small amp (speaker wire in/speaker wire out) that could sit in between the player and the speakers that would help?
**title should be "Low watt output to higher watt speakers", without the extra "high"
