Status
Not open for further replies.
1 - 2 of 2 Posts
Hey everyone,
I've started working on a LP340 DIY hushbox - to test the design I came up with I made the thing in... cardboard from the original package :)
After taking a good look at the whisperflow design I've tried something similar in cardboard, but with the incoming air "tunnels" on top instead of the bottom (bad choice I know as heat goes up)
I didn't use vents yet (have to buy them) and the temperature really went through the roof after 15 minutes but the machine was really quiet... I'll post pictures ASAP to have some ideas from all of you to improve on the final design.
My biggest question is heat... what would be the maximum ambient temperature for the LP340? Will it shut down when too hot, or will it already be too late?
Yves Smolders
Discussion Starter · #2 ·
No-one has experience with LP340/350's shutting down when too hot???
Yves Smolders
1 - 2 of 2 Posts
Status
