Status
Not open for further replies.
1 - 2 of 2 Posts
I decided not to ceiling mount my LT-150. On the other hand, my coffee table isn't properly located. Has anyone used a good (camera/video camera) tripod? If so did you make a flat platform that locks to the tripod and rest the projector on that? or did you adapt the projector directly to the tripod?
I will probably try the first.
loganross, as I recall, someone did mention that they mounted their LT 150 on a tripod.
They first secured a platform to the tripod, they then mounted the pj on that, then they secured the pj to the platform to prevent it from slipping off. How they secured the pj ecapes me a the moment.
The tripod offers you a few options of where to place the pj in relationship to the screen, as well as adjusting the height of the pj.
When you're finished, you can put everything away easily!
HTH, VB
1 - 2 of 2 Posts
Status
