Status
Not open for further replies.
1 - 2 of 2 Posts
Has anyone else experienced this? The venting fan on the right side of the projector is a bit loose and vibrates against the plastic vent housing. LOUDLY. A little pressure on the fan towards the interior elinates the noise. I was going to try and open it up and come up with a solution for the fan, wondered if anyone has done the surgery. I'm not real excited about sending the projector to Dell for repair for such a minor issue that is obviously due to bad construction. The projector is relatively new < 3 months.
Thanks, Ben
Call up NEC and get it replaced. I had the same problem and had a NEW projector the next day. If you have over 100 hours on the bulb, you'll be getting a bulb with less than 100 hours in return.
The NEC service was outstanding.
Mark
1 - 2 of 2 Posts
Status
