Hi Guys,
I need to pick the brain of someone who owns the LT150 and is using it with a 16:9 screen (maybe one of you luck b-stards who picked it up for $1500 on Dell
Assume the following:
1024x768 Native Projector Res
16:9 screen
480p progessive video source (720x480)
Anamorphic 16:9 DVD Content
Standard lens (no Panny's)
So given the above, what resolution will the LT150 display converting an anamorphic 16:9 source on its 1024x768 4:3 panels?
I did some quick calcs, and assuming the projector would devote the full horizontal resolution of the panel to the image, it would scale the 720x480 source to a 1024x432 area within the panel. This assumes square pixels (which I think is more or less the case)
If this is how it handles things, then how is the 16:9 rectangle oriented within the 4:3 panel? Top or bottom justified, or centered?
Another question: Let's say the projector top justifies a 1024x432 16:9 image. So I set up my screen and projector orientations so that a 16:9 anamorphic source displays properly and fills my screen. Now what happens if I want to view 4:3 material but don't wan't it stretched and scaled to fit the 16:9 screen?
Ideally I'd want to have the 4:3 window centered in my 16:9 screen. But if I display the 4:3 source at the native res of the panels with the same screen/projector setup, then the 4:3 image will fill the width of the screen but about 330 scanlines will fall off the bottom of my 16:9 screen.
So I guess in order to avoid having to remount the projector when switching between 16:9 and 4:3 material, the projector would have to scale any 4:3 material within the 1024x423 16:9 rectangle mentioned above. This means scaling a 720x480 source to a 575x432 window centered in the 16:9 screen. 4:3 material could look pretty crappy unless the internal scaler of the LT150 is decent.
Another stupid question: What happens when you want to view letterboxed material? Can you treat it as 16:9 material and zoom it to fill the height of the screen?
If the LT150's scaler isn't up to handling all this stuff properly, than can something the QuadScan handle all these scaling gyrations?
Anyway, sure would appreciate any insight you can share. If the LT150 can handle a 16:9 setup in a reasonably efficent manner,then its a huge deal at under $2K.
Best,
Mike
16:9 screen
Best,
Mike
