Equipment:
LT150
DTC-100, RGB to proj
HTPC, Radeon (1024x768x60)
Everything had been working great. I don't know what if anything changed. Image through the HTPC is fine. When using the DTC100, regular 4x3 channels no longer fill the whole panel. They seem to be cropped into a 16x9 segment of the panel. HD signals are also not right.
I have messed with the screen format, and retrace timing settings to no avail. Retrace timings have no effect at all. Screen format settings will change the image, but it is still always cropped into the "16x9" panel. I've never tried it (no progressive component sources hooked up), but it seems like the projector thinks it is in the cinema mode even though its in rgb.
I hooked the DTC up to a regular monitor, and the picture is normal.
I tried resetting the projector to factory defaults for all sources.
Using the horiz, vert, clock, and phase settings moves the image around in the same "16x9" panel.
When looking at the info page with the DTC connected, the projector sees a 540P signal 59.xx refresh.
This is a new problem, all had been working well. HTPC signal fills the panel.
Any ideas?? This one really has me stumped!
LT150
