Hi Jon,
Orientation can be
1. Front projected from a table
2. Front projected from the ceiling
3. Rear projected from a table
4. Rear projected from the ceiling
This projector can be placed behind a "special" screen, to achive a rear projection. I'm assuming you will want Front projected from the ceiling.
All of these choices effect how the image will be projected from the projector. For ceiling mounting the projector is upside down, thereby inverting the image. The projector compensates for this. For rear projecting the image will be backwards, the lt150 can correct for this. If you are ceiling rear projecting the image will be up-side down and backwards, luckily the lt150 can straighten this out.
Hope this helps.
Todd
-scan-lines-annoy-me-
