1 - 2 of 2 Posts
Just moved to the UK and brought my trusty LT150z. I've got a SKY+ HD receiver and am trying to hook it up to the projector. The projector is set to component video and the pj works fine with a DVD player component source (I have a component to 15pin cable). It does not work with the signal from the receiver. The pj manual claims 720p and 1080i support, but neither receiver setting works. I get a "out of range" message on the projector. I did confirm that the component output works from the receiver with another display.
Any suggestions? Or do I retire the 150z and get the HD70? TIA!
-Charles
If you can afford to, it's time to retire the LT150. It was quite a champ when it came out, but you'll be amazed at how far projectors have come since then.
1 - 2 of 2 Posts
