Status
Not open for further replies.
1 - 6 of 6 Posts
I was wondering if it would hurt the unit by using an extention cord. I have my LT150 ceiling mounted and I do not have a ceiling fan or light outlet near projector to tap into.
I plan on using a 25' (same diameter size as power cord) extention cord pugged into a surge protector.
Is this ok? Any advice?
Should be fine as long as the wattage rating is OK for the cord.
Vettster,
It should have a current (amps) rating. The LT150 manual will tell you how many amps of current it pulls, the extension cord can handle more than enough to handle the current draw of the LT150.
Considering there is already 100' extension cord running inside your walls back to the circuit breaker, another 20' won't cause a problem.
1 - 6 of 6 Posts
Status
