This will probably get lost in all the posts about the hot LT150 deal from Dell… but here goes anyway. I haven't seen an LT150 in person, so take this with a grain of salt. I did just take delivery on a Seleco HT200DM (purchased from the good folks at AVSCIENCE).
I'm still putting my HT room together, my GrayHawk screen hasn't arrived yet, and I've only been able to see it on a white painted wall with a too-short viewing distance. However... based on what I've seen so far, I am absolutely floored by the image quality. Blacks are a deep black, there is LOTS to see in the shadows, and reds are true red. It's a gorgeous, silky-smooth image.
The HT200DM has a special "native" 848 x 480 chip mode, so the projector can take a 480p signal from a progressive DVD player with minimal scaling artifacts. The better your DVD player, the better this projector will look. It looks stunning right out of the box when hooked up to my Panasonic RP91. No fancy outboard hardware (like Panamorph lenses or scalers) is needed. It’s reasonably quiet. It has high contrast optics, and it’s sealed against dust intrusion. Good optics are expensive, and it’s one of the places where cheap projectors cut corners. The company has an attentive and friendly customer support presence here in the U.S., which is more than you can say for most Japanese companies.
Is it worth the cost difference over the LT150? I dunno, that depends on your budget and what type of source material you want to watch. It was worth it to me, since I mainly wanted a projector that did a terrific job with DVD movies. Everything else I watch is secondary to that goal. The only projectors I saw in person that showed a better picture than what I’m seeing on the wall right now, were big hulking $20,000+ CRT projectors.
Here are some possible drawbacks to the HT200DM:
With the relatively low pixel count, it’s not going to do as well on HDTV as some higher-res projectors. That doesn’t bother me too much. This is a tricky time to be buying HDTV hardware, with the current controversies over Firewire inputs and 5C copyright protection (see the threads in the HDTV Hardware forum for more info). Right now, I'm glad I bought "only" a DVD-optimized projector! This may be one of the few projectors you can buy right now, and feel completely comfortable about your decision. If I had bought a higher-res projector, I'd be obsessing over the lack of Firewire inputs.
The focal length is a bit long. If you have a small room, you may have trouble getting a big enough screen. They designed this for people who didn’t want a projector hanging over their heads.
With the 6-element color wheel and the redesigned red filter, it’s not the brightest projector out there. I can’t make a good judgment on this with my test setup because the room is small, but it sure seems bright enough to me. I’m planning on using it in a bedroom with complete light control and a 72†wide (16:9) GrayHawk screen. But it might not be bright enough for a 123" screen. Maybe some other HT200DM owners here with larger screens can comment on this.
[This message has been edited by foldedpath (edited 07-24-2001).]
